CajunMan89
The book for my John Deere LA115 says to use general purpose grease, but I find that grease doesn't last long. So my question is, would it be a good idea to switch to high temp. grease?
I have used both and see no measurable difference. I put 3 pumps every day. That is 8 hours of mowing. My personal opinion is the time they tell you to grease is way too long of time. My mowers all perform better with grease so I grease them often.
Theses days it does really pay to grease the bearings because most of them r sealed. U can over grease causing a load on them more than they need leading to premature failure. On most units the fittings r there for one reason for heat transfer purpose only.
