How many hours on yours ? My TC 4260 has 84 hours & quiet, @ 3.5 yrs old.
But you could easily remove the deck, & check each spindle & each pulley by hand rotating each separately for noise & or excessive looseness.
The decks come off very simply & doing so un-hooks the deck belt. It's described in the owners manual or Youtube.
Deck removal: Lower deck to lowest setting, remove front connection point at deck. Let it on the ground, gently push deck back towards rear of machine so the 2 rear lift hooks unhook off the lift bar, the deck belt will loosen (Pay attention to where the belt goes for re-assembly) & remove it from machine.
Then check each (one at a time) by spinning each by hand & listening. The guilty party should be revealed. Replacing either a spindle or a pulley will be pretty much common sense then.
Good luck & Keep us posted to what you find.
