A ARMADA175 Member Oct 9, 2017 #11 LawnWorld is a real nice site I wish I could find a automobile repair site this good>
primerbulb120 Lawn Addict Oct 9, 2017 #12 Pulleys will have to be changed if you want it to go slower. Or you could put on a set of worn out drive wheels with all the tread gone to reduce traction.
Catherine LawnWorld Support Oct 9, 2017 #13 :welcome: I'm going to move this thread over to our Troy-Bilt section. :smile:
zman111666 Well-Known Member Oct 9, 2017 #14 Any chance the engine speed is set too high? Shouldn't be going faster than 2800-3000 RPM.
A ARMADA175 Member Oct 10, 2017 #16 Yes throttle RPM has been moved to Maxim, motor handles with no problem Do not know what the RPM reading is.
A ARMADA175 Member Oct 10, 2017 #17 I'm going to move this thread over to our Troy-Bilt section. Where is Troy-Bilt section? Thank you
primerbulb120 Lawn Addict Oct 10, 2017 #18 No cable adjustment on these. Unlike some models they don't use the belt to engage the drive, the engagement mechanism is inside the transmission.
Ronno6 Lawn Addict Oct 10, 2017 #19 ARMADA175 said: I'm going to move this thread over to our Troy-Bilt section. Where is Troy-Bilt section? Thank you Click to expand... http://www.lawnmowerforum.com/forumdisplay.php/23-Troy-Bilt-Forum Under "Forums" look in the "Equipment by Brand" and go to "Troy Bilt"
A ARMADA175 Member Oct 10, 2017 #20 primerbulb120 said: No cable adjustment on these. Unlike some models they don't use the belt to engage the drive, the engagement mechanism is inside the transmission. Click to expand... Great answer I will leave subject alone. Thanks Kevin
