hrdman2luv
Your push rods or 1 rod is not in place. You don't have to take the head off to put them back in the right way, just loosen the rocker arms..
When I was adjusting the valves, they were opening and closing as they should.
What did you set them at ??
Did you check the valves on the inside of the head to see if they seated properly while you had the head off? An unseated exaust valve would cause a no compression issue.
Is that MM or thousands ?Int.05 & Exh .08. The exh was a little tight. But the feeler would still slide.
Thousandths. I think the MM was 10 & 15. Being that there's a 3 thousandths tolerance on these, makes me think it's not real critical. But where I set them was within tolerance. Unless something came loose when I tried to start it.
They were snugged up. I double checked that before I put the valve cover back on. Triple checked the gap.
That has the be a translation error.
No one runs 50 thou or 80 thou on the valve lash unless you got a blower and are using nitro.
0,5 & 0,8 mm is aboyt right or even 0.005" & 0.008" could also be right.
