- Nov 29, 2014
- 24,995
If there's anything plastic in that engine, acetone will attack it.
Kerro is the go .
Has been so since the first internal combustion engine was made.
Put some strait kerro in , take the plug out and give it a lot of pulls.
You can over fill a bit because you are not going to run the engine.
Leave it in the sun so it gets warm and come back every hour or so and give it a few more pulls.
At the end of the day, week end , week whatever drain the kerro out.
Refill with the 50:50 kerro oil mix and run the engine on low idle for 10 to 15 minutes then drain & refill with fresh cheap oil
Go mow your lawn then change the oil again
Change the oil again at the end of the season.
Check under the engine because usually the lower oil seal will start to leak after all the crud sitting on top of it is removed.
