+1Well... just for fun I'll come to the defense of the Fastrac since I came from an SD to a fastrac...both 54".
Fastrac pluses.....
It's a heavier-duty unit sporting more weight and the protection of a roll bar if you need it.
You get an extra year warranty
Bigger fuel tank and roomier operator station. Electric fuel gauge.
Both my units had the Kawasaki engine but the fast track is much quieter.
You get the next Notch heavier hydros and for some reason they are much more accurate and less jumpy than the ones on the SD.
The traction is noticeably better for some reason... must be the extra weight /taller tires yet for some reason it seems to leave Les tire tracks when the ground is soft.
The front wheels stay planted better.
The open design of the mower deck discharge is better and keeps the deck cleaner on The Fast Track.
The deck lift linkages are much heavier Duty and the lift assist spring is really sweet when you're dial it up to help you lift the deck.
Fast Track definitely rides better on rough ground
I like the deck adjustment pin setup better.
For some reason it leaves a little more striping effect.
That's about all I can come up with right now but I would buy it again and spend the extra money in a heartbeat.
Boyler,
I've told this story before. I have a SD60, neighbor across the street has the most expensive Hustler with a 52" deck. His runs 16 mph, mine runs 7.5.
We both mowed my yard, we both mowed his yard. My little ole cheap SD took less time to cut both yards and that is mainly because I cut using my entire deck, he cuts loosing about ten inches of his effectively making his a 42" cut. I cut my yard which is larger than his by a third in a quarter less time. Plus, mine rides better than his. I thought I wanted his until I rode it. Staying with the SD60 although some say I should get a 54 so it won't scalp. Wouldn't it have to first scalp in order to not scalp? lol I call BS on a narrower deck.
If you got it, flaunt it. I'm not into mowing, I'm into getting it over with. lol.
I haven't found anything the SD doesn't do just as well as a Fastrack, XOne or any other Hustler with the exception of wheelies. Dang thing won't wheelie yet. That is coming.
Max
I test drove both when I was looking for a mower. Went with the SDX during the Raptor Season Sales event in June/July, combining it with the 10% off coupon and a bunch of GC's lol
Once I drove both, it was an easy decision. Steering was smoother, ride felt better. Even the regular SD seat felt better. I believe the SD60 & SDX have the same or similar seats. SD54 had a little less cushion, but still better than the Husky. If you can, sit on them both and see what feels better to you.
I believe the big difference between 2016 & 17 is 17 has the Kohler engine with the cylinder or canister style air filter and a bigger oil filter. The air filter is inside that big hump on the back of the engine.
If they're priced the same, go for the 17
Good Luck
They are out of 2017 models, but will sell you a 2016. Sit back and think about what you have gone through, do you trust them? I can't believe there are no 2017's available, don't think they want to work with you, just want to get rid of old stock. What does your gut feel like right now? I would start over and really think if I want to go with a big box store. Maybe time to start looking at dealers, who know what is available in their lines. Just my two cents worth.
