hrdman2luv
I have a Troybilt 12AT609G766, that when I disengaged the deck belt, the blades continue spinning. The belt is loose. So loose, that I can (after shutting it off) can take it off any pulley without much effort. The belt itself, is a little worn, but not too bad, as it cuts great, when it's mowing. The routing is correct. I can't see anything hanging up on the deck levers.
I'm stumped.
One thing out of the ordinary, the pulley brake on the drivers side, rubs the bottom of the pulley.
Any clues? Sorry if this has been posted before. I'm not real sure how to search, other than going through a lot of pages of threads.
I'm stumped.
