Pull cord has some tension but does not turn the engine
Sounds like the same problem I am having . Are there 2 little springs in there too ?
Which of these parts / repair kits look correct for this application ?
https://www.ebay.com/p/Rotary-13587-Starter-Pawl-Kit-for-Briggs-and-Stratton/1308809514
Thanks , :-)
Wyr
God bless
I have not been able to get the screw off yet to answer your question about the springs. That said, I did order the item below so once I do get it off, I'll have what I need. I think I only need a new screw but the screw price on amazon is about the same as the ebay item below.
http://www.ebay.com/itm/Rewind-Star...9-281505-691696-13587-Free-Ship-/252639034035
Used a nut driver attachment for my cordless , to remove the screw on mine .
The photo in your link barely shows 2 springs , each in a track of the black plastic " plate " . Interesting .......
Please let me know how that turns out , when you receive the parts .
Thanks , :-)
Wyr
God bless
Thanks , :-)
Wyr
God bless
I'm not very mechanically inclined so bare with me but how did you use a nut driver to remove a screw?
Thanks , :-)
Wyr
God bless
Yes I agree that is not the right part you ordered. I wish you would have said something about buying one earlier I would have given you one for free........
I ended up cutting out the friction plate using a hand saw and then I had enough room to use locking pliers to remove the screw. I noticed the friction plate has no springs and the ebay item I purchased has springs so is this what you are referring to as far as being the wrong part? Furthermore, there are two issues I see with the bottom to the friction plate. First, in the two pawl slots, one slot has a pin that fits into the pawl. The other slot looks like the pin has broken off. Second, while cutting the friction plate off, I accidentally cut into its bottom backing. Both of these are illustrated in the attached images. Am I still good go to in installing a friction plate on these two issues or do I now need to replace more parts?
Yes that what we were referring too as the wrong part. When I quoted on Wyr Twisters post. I have several of those if you want one let me know all it'll cost you is the shipping cost. It will be the whole assembly ~!~!
