PyhooyaBooya
I just purchased an MTD 42" lawn tractor. Thus far I really like the cut of the mower, but when I make corners (mostly on hills) it's like the deck is lower on the outside of the turn. How do I fix this little issue?
So I should be cutting in strips even though it isn't a zero turn? Would it help if I put more or less air in my tires. I don't know what psi I am running.
