Scag buzzing sound under key when turned to start
Civicb16
As the title says, I have a scag turf tiger 61 in cut. When I turn the Kay to start it has a buzzing noise under the key in the ignition box area. With no engine turn over or start. I am lost to where I need to go next to figure this out. Any help appreciated. Also I think this is a 03 to 05 model with 600 hours. Thanks
You can start with the full model number from the tag.
While you are looking for that, remove the battery and charge it
take off the battery leads clean the end of the leads where they bolt onto the mower and paint them with liquid electrical tape to prevent further corrosion.
Also check that the bolts which hold the engine down are tight.
Mine did the same thing. Replaced the battery and now all is well.
Jump start it. Run engine at full throttle and check battery voltage with voltmeter. If below 12.7 volts, you probably have a charging problem. If above 12.7 volts, you may have a bad battery or dirty/corroded connections.
