mechanizm
- Jul 30, 2017
- Threads
- 12
- 93
ok, i had the carb-float stick closed on me so i got that fixed. i fired it up and it ran good until i idled it down and back up. the funky mechanism that controls the rpm is not allowing the butterfly to open properly and it starts running super-rich and chugging badly. i can open the carb butterfly by hand and it tachs up well but i just can't control it from the cable. i had this problem long ago and fixed it but now my brain isn't working. if i remember correctly the throttle linkage needed lubrication because it was sticking. i may slather it with D40 tomorrow. is there an easy way to circumvent that maddening and complex idle-up / down and just hook the cable directly to the carb butterfly?
THANKS!
THANKS!
