The pins 51 & 45 will both be roll pins and you will not be able to drill them out they have to be punched or pressed.
I use cheap pin punches m machined down to the size of the hole in the middle and the outer diameter then a G clamp to press them out.
Your skipping is because the gear on the shaft shown in the last image is not meshing properly with the fan gear part # 47 and usually it is because the bearing at the bottom of the shaft has worn allowing the gear to move just enough so that the teeth skip.
When you have it off generally there is a hole that had nothing in it.
That is the index hole and it will align with another hole when the gear is directly ahead.
This is a good mower as all of the drag linkages have adjustable tie rod ends so you set the fan gear to strait, set the steering wheel to strait, engage them then adjust the drag links to give you the correct toe in and the rear wheels to be strait ahead.
If the tie rod ends are really loose they might need replacing but luckily they are standard engineering parts available from engineering supply shops & most farm shops.
Grab the fan gear, if you can move it back & forth then it's pivot hole is flogged out oval or the pivot pin # 49 is worn oval & it will need to be repaired.
The steering gears are awkward to get at so no one ever lubes them thus they wear.
The one I did was branded Husqvarna so had a different bady and a stronger front end but the rest was the same .
