Jetblast
Tetraethyl lead was originally added to combat knock. The fact that it lubricated valve seats and stems was a bonus. It's still used in 100 octane aviation gasoline because you just don't mess with less effective substitutes when you could fall out of the sky.
Yes, that will be a slow change if it ever happens at all.
Lead is great in gasoline but when it was in automotive fuel it literally sprayed out the tailpipe onto roadways, and got washed into adjacent soil and ditches. Anything grown in that soil was toxic. After running a roadside lemonaide stand all summer, little Johnny didn't do so well at math and your goats tried to have big **** time with your cows.
Aviation engines don't care about the environment and there's little reason they should. There are few of them, comparatively speaking, and they blow their lead over wide and often unpopulated areas. Lead is great for them as they must have an optimal power-to-weight ratio at reasonable cost, which is helped by high compression. Since so many piston airplanes are flying around without hardened valve seats, the cost of upgrade would ground a tremendous number of them. General aviation has a hard enough time surviving without that.
