Pull cord fine, crank shaft will turn but not when pull cord pulled
yinyang
Troy built self propelled replaced pull cord, now even though crank shaft will turn manally, when pull cord is pulled, crank shaft wont respond?
So does this troybilt have a briggs, kohler, kawasaki, honda, mtd, engine. How about a model number of the engine
Without knowing anything about the engine or even any details about the manner in which the crankshaft 'won't respond,' I would say you installed the new cord wrong.
Try again.
