ricktucker
- Jul 10, 2017
- 2
Recently replaced the torque strap in the rear end. Since then, the cooling fan on the rear end knocks the belt off the pulley when the drive belt is disengaged to start. I have replaced the drive belt thinking it needed to be replaced, but still does the same thing. Could I have changed the angle of the fan when replacing the torque strap? Also uninstalled and reinstalled the clutch springs, I believe I put them back correctly. Any suggestions?
Rick
Rick
