shelby5041
- Jul 7, 2017
- 32
hi
i have to say im struggling with this one..i have been tinkering with this weedeater PE550 gas edger for a couple weeks now...it started ok couple years ago but now it will not start now.
i will give you some condensed info of what i have done so it may help you direct me to next step to get this thing running or trash it
during my process of troubleshooting it this year....the primer bulb and gas lines fell apart...so i have replaced those with new parts.
i do get spark....and .if i put some fuel in the spark plug hole it tries to start after about 10-15 pulls....it struggles but eventually it will start for a fraction of a second...
i took carb 100% apart and cleaned with carb cleaner.....i then reassembled and still no start
i can push the primer 100 times and when i take spark plug out i see no sign of fuel....is this normal?
would a carb rebuild kit fix this?....carb needs replacing?...or could i have another issue why it wont start
carburetor is a walbro wt-630 i believe carb with primer bulb built in....pretty common on many 2 cycle yard products
any help would be appreciated...
thank you
thank you
