Ventrac
Hi I Just found this site from My customer (glor51) mentioning it. Found the Issue with this tractor the neutral bypass valve in the head of the hyd pump loosened up and was letting the Hyd Fluid Bypass the drive Circuit.
Scott
Hey Scott, that is what Chad had figured, but he wanted to talk with the customer to know a little bit more on how the unit was reacting. Good to see you figured it out and welcome to the forum! :thumbsup:
