yard machine 21" not getting gas
eagle86801
I can't figure out why this machine isn't getting gas. I took off the carb and cleaned it out twice. drained the gas tank. It will start if I remove the spark plug and spray starting fluid in the hole . It ran fine last year after I tuned it ,I changed everything. I only use it for a small piece of lawn 30' x 8' . I can't figure out the gas issue . Thank you
Boobala
OK we know it's a Yard Machine 21" , .... how about some info off your engine ..?? see example.....
eagle86801
Yard Machine model 12A-A1BA729 Serial # 1B195KC1492 Year made 2014
This number was listed below the model and serial numbers 339796
Briggs model 9P702-0149-F1 Briggs serial number 1406105418641
550E 140 CC
eagle86801
550E 140 CC
