papalump44
Hello all, I'm still very new to this forum stuff so I hope I'm in the right place asking my question. My Dixon SPEEDZTR 42 will not go very fast in forward. When I push the levers forward slowly, it starts to move, but if I push them farther to go faster, the machine makes a strange noise that is in my opinion is either hydraulic starvation or drive belt slipping. I dropped the rear end units, ie both pumps and transmissions, and checked the fluid. The fluid is about an inch below the hole as I was told it should be in both units. Could it be the belt is slipping under load or do you think my fluid has broken down and should be replaced or are the pumps shot?
