Honda GCV160 motor stalls if shaken
flash_os
Easy start but when start mowing or shake lawnmower then motor stalls.
Last year I disassembled carb and cleaned because it's use to work only with half choke.
Any suggestions?
Any suggestions?
Hello, have another look in your carb bowl , if you have a bit of water in the bottom and as you shake it it may put a spot of water into the jet and stop the engine .Gary
Removed and cleaned bowl but didn't help. :-(
Hello, just another thought, have you checked the fuel flow from the fuel tank as something at the bottom of the tank blocking the outlet may move when shaken to give a bit of fuel until it runs out .As i say just a thought . Gary
