Riding Lawnmower Rescue Lifegaurd needed-Sharks are circling!
DjDrew
LOL....
I have an older model Murray 36" riding lawnmower with a 12 HP Briggs "Power Built" vertical shaft in it.
So far I have replaced a new carb, spark plug, fuel filter and all lines. Simple fixes but no luck.
The rider operates fine when it is cold and first started up, and mows well. But once warmed up it goes to pot, runs intermittently going good for 15 or so seconds
then spurting and coughing and back firing for 5-10 seconds, then once again pulls and runs good for no more than a 15-20 second period, then once again spurting, coughing and back firing.
It keeps doing that unless you let it cool completely down, then recycles all the way through again, running good till warmed up and then spurting
and backfiring then running good and once more again farting through the carb.
I am hoping it is not anything internally broken, but since it is interment I am wondering if the problem is something else.
What is the timing system on this or can maybe the firing system/coil/armature electrical on this be going bad and thus backfiring then running good?
The consistent, without fail 15 seconds good, 5-10 seconds backfiring then back to good is what has got me wondering.
Seems to me if it were bad valves or something it would be continuously firing bad once warmed up.
Please keep this girl out of the scrap yard. Disabled 60 yr old here so I cannot afford to replace her.
thanks for the help in advance.
New member with sparse knowledge on this model rider and engine.
Drew
Also, while throwing advice in here, how do I set the adjustments on this single carb, only two adj. screws on here. See attachment please.
Thanks again.
My guess would be the ignition coil. No easy way to test this, either.
The two screws are idle speed and mixture. Idle speed is the one that contacts the throttle shaft. Pretty obvious how that one works. The other will have an "initial" setting, usually 1 1/2 to 2 turns out from closed. This will be good enough to get the engine running and once it's warmed up, you turn the screw out until the engine starts to run rough, then slowly turn in back in until it starts to surge or die, then back it out a quarter to half turn. Then adjust the idle screw to whatever you wish. If the engine was already running rough when you started it, skip the step about backing out the screw.
Look on the engine for MODEL, TYPE and CODE numbers and post them. That will help immensely.
Thanks CPurvis:
i will check those tips out tomorrow and see what happens and then repost to let you know the outcome if any.
Get an inline spark tester ( red tube ones are the best ) and some starter fluid.
Put the tester on and start mowing.
When it plays up, look at the tester ( dark place will help ).
If the tester blinks or fails to blink in time with the engine spluttering then your coil is the problem.
In this case, remove the blower housing and pull the small wire off the coil.
Fire up the engine and watch the tester, problem goes away then you have a problem with the cut out wire shorting out ( or ignition switch shorting out ).
NOTE if this engine does not have a fuel shut off solenoid you can only stop it by replacing the small wire or pulling the spark plug lead.
Thanks so much for the info...its a learning experience. Haven't gotten a chance to get out there and play with it after posting but plan to soon when the coil gets here.
Will be sure to post and let everyone know how it is going.
As a pre-thought consideration...where is a good place (website) source to look for running known good used 12-12.5 to 16 HP vertical Briggs engines at?
Not sure if I need to replace but wanted to compare price worthiness if repairs go that far.
Thanks again...
Thanks again...
Google mower breakers.
There is not much money in it so there are not many breakers / bone yards out there.
Labour costs make it a no brainer for repair shops and there are very few owners who bother when they can usually pick up perfectly good mowers at the local tip that require little more than a new belt or plug.
Sorry for the delay. It has taken this long because the coil I bought new turned out to be defective DOA and I had to wait again for a new replacement to ship and get delivered. Put it on today, and it started and ran good, but idled terribly fast and got hot to quick so I had to shut it off and let it cool down. Now I think I am having problems with it either flooding or a carburetor adjustment and have to play with it for a bit. Having to charge the battery in between testing intervals so it is taking a while.
I was asked for model number and such so here that is.
Murray 12HP Power Built B&S vertical shaft 36" riding mower
model #: 284 707
type: 1026-E1
code #: 020123ZD
Ignition coil #: 591459 replaced aftermarket
carb #: 799728 replaced aftermarket
SO once I figure out what the problem is with it starting and idling I will get back with everyone. Thanks so much for the help from everyone.
model #: 284 707
type: 1026-E1
code #: 020123ZD
Start the mower then go around to the carb.
manually work the governor lever.
If you can slow the engine down to proper speeds then the governor is incorrectly adjusted or broken internally.
Okay, choosing this post because it dealt wit the cut out wire.
Here is what has happened since I last wrote (next to this last bottom post by me)
I have been going round and round on this. After determining that the first coil I bought was supposedly bad (from TEK but maybe cheap Chinese aftermarket)
I then waited for the replacement. Once installing the replacement it fired up and seemed fine but I didn't even make it to a test run on the yard before it failed to start again.
So I switched back to the old coil that had been cutting out originally and it fired up but of course the same problem of sporadically cutting out when under a load .
So I did some swapping between old and new and replacement carbs and coils and still have not gotten it to fire up like it use to, so easily before all this and it would almost always fire right up. So I pulled the plug, it was new as of three weeks ago, and it seemed fouled a slight but with all the dead start tries and then running to fast and a bit hot so I cleaned it up and am going to put it in and try again>
Now why I referred to this cut out wire is this.
If I unhook the cut out wire, that completely eliminates any ignition switch or wiring problems right? I should be able to cross the two battery terminals under the seat, the ignition and starter terminals, not the ones on he battery itself, and it should fire right up correct? I had done it this way before, just using the terminals and crossing it over and it worked every time before this coil problem arose. But now it seems that it is just dead. I presume this second coil ran for a few minutes and then went DOA dead. I am putting the old coil on, going to test it and then get back to you all. But removing the coils cut out wire that leads to and connects to the ignition switch "off" wire, it should eliminate the switch and allow it to start correctly, right?
I have not yet gotten a spark tester and ran it what with all the way and in the order of re-occurring events after trying this new coil out.
Hope I am not turning this into a big confusing mess but this eliminating the cutout wire would of course tell me if I have ignition switch problems true? That is if it is agreed it SHOULD start.
Waiting for a reply folks, and thanks for your patience. I will at least learn procedures for diagnosing the ignition at least on these little 12HP Briggs when done. :)
