toomuchgrass
I have an M60 Tank with the 23 HP Kawasaki engine. It has a little over 500 hrs and the clutch started not wanting to engage so I adjusted the 3 screws on the clutch so it engages most of the time - sometimes have to rev engine. Problem is I just put a new battery in and either the clutch is draining the battery or it isn't charging properly. I have a multi-meter so I guess I need to start checking and see how much voltage it is putting out when running?
