storm-chaser
This uses 40:1 and has a displacement of 25cc. 17" cutting pattern, standard trimmer string. Only about 1 hour run time on engine and it did this right out of the box. If you start it and press the throttle about 1/2 down, so the throttle plate is 1/2 open, it runs powerfully and cuts the best. If you go to full throttle, bogs and slowly spools up, but doesnt have as much power. How can this be, since everything else I've worked on runs better when the throttle is wide open. I even went as far as to remove the choke plate to test - but it made no difference. I can always run it have 1/2 throttle, but it seems like here must be something I can do to make it run powerfully at WOT. Any suggestions? Again this is a like new machine with good compression.
