I needed to replace the primer bulb and removed the carb to do it.
But stupidly didn't take this photo before doing that, so now I want to see if I have the linkage in the correct hole (it won't run above idle unless I operate the throttle by hand).
Does it go in hole A, B, C or D?
I hope it's not D, because that means something else is wrong with it rather than my screwup.
Thanks,
Tom
Thanks,
Tom
