L110 Will Not Start
Dirtbmw20
I have a L110 that when you turn the key, the mower does absolutely NOTHING. The lights DO come on, and the hour meter DOES work, but other than that there is nothing. No "trying" to start, no clicking, absolutely NOTHING !!! I have owned this mower for probably about 10 years and never had this problem before. I HAVE had the problem of the starter solenoid going out, but I have replaced the starter solenoid and that does not fix it.
Is there a switch of some kind on the brake pedal ??? Since that pedal MUST be pushed in before the mower will start......
SOMETIMES (maybe 1 out of 10 times) I can keep the pedal pushed in, and rock the mower back and forth while having the key turned, and WHALLA..... it will start. BUT like I said, that is only 1 out of every 10 times. Couldn't get it cranked at all yesterday
If I jump the terminals on the starter solenoid with a screwdriver, it will start up. But I have THREE different starter solenoids, one being BRAND NEW, and another "confirmed" good one, but even if I replace the solenoid, it does NOT fix my problem.
WHAT GIVES ?????????
bakerg
Safety switches on the seat, brake and mower engage, check them all.
Dirtbmw20
My first thought was one on the brake pedal, but yesterday at home I couldn't find the damn thing located on the mower. NOW that I got to work and can get on a real computer (no PC at the house, only phones), I have found where the brake switch is located so I will check that.
If ANY of those switches are bad, would the mower still start when I jump the terminals on the starter solenoid ??? Because as I mentioned, I can jump the terminals with a screwdriver and it will start and run just fine.
Boobala
My neighbor had the same problem last year... HIS was solved when he ran an EXTRA ground wire
from the ENGINE to the SOLENOID FRAME ... he said screws holding the solenoid didn't provide enough
metal to metal contact ... course his solenoid...grounds through its frame...not from a terminal as on 4
terminal solenoids .
The Seat switch has absolutely nothing to do with the starting circuit, Leave it alone.
The power to energise the starter solenoid goes from the ignition switch to the PTO switch then to the brake switch then to the starter solenoid.
This is a daisy chain so if any one is bad it wont crank.
The switches are simple plunger switches so they should be in starting mode when the plunger is all the way in.
They are cheap I simply replace them as that is a 10 minute job as compared to a 60 minute job running bypasses to check each switch individually.
Both have 2 circuits.
One is a power ( +12V ) and closes plunger in to start the mower
The other a ground circuit and goes closed to shut the mower down, plunger fully out.
mjb8fj
bert is right on the money, the seat switch has nothing to do with it turning over. If you have tried what he has said so far, and the other suggestions, and its not working, use a DVM (volt meter) and look at the solenoid- one of the big positive cables should have 12v the other 0v, try to start one should have close to 12v (if it does turn over its under a load and voltage will go down) and the other side should have close to the same voltage. So 12v on one side and 12v on the other when starting. If you don't, the solenoid has gone out, no biggie the go out all the time, if you got 12v going in, and 12v going out, your now looking at the starter not working. I think I read that you already replaced two or more previously over the years, well they do go bad. If your jumping the solenoid with a screwdriver, is it because the solenoid crapped out, or cause the brake safety isn't working? Key switch? There is only a few things to try, and its hard to help you out online or thru a forum but theres a lot of help here for ya. I have one of the 110's as well, not a bad machine at all.
Telesis
Let me apologize for this great american novel. My purpose is to help you understand how the components work.
Think of the solenoid as a simple but heavy duty relay. The two spade terminals are the coil connections. The two studded connections are the contacts. When 12v is connected to the coil(via the purple and black wires connected to the spade terminals), the internal heavy contacts close connecting one of the studded terminals to the other, in turn connecting the heavy battery red wire to the heavy starter motor wire and the engine turns over. The purple wire provides the +12V to the solenoid coil(when you go to start it) and the black wire is connected to ground.
Another simple way of checking the solenoid is to remove the purple and black wires from the spade terminals. Connect a jumper wire from one of the spade terminals to the positive batt terminal and another jumper wire from the other spade terminal to the negative batt terminal. If this causes the starter to turn the engine over, both the solenoid and the starter are good. If the starter does not turn over, the solenoid is bad. By doing this test, you are bypassing all the wiring/switches, etc that provide the power to the solenoid coil.
If the solenoid is good, then you need to work back. Reconnect the black wire to the solenoid spade terminal. Touch the jumper wire from the other to the positive battery terminal again. This tests if the solenoid coil is grounded good. If it turns over, the grounded side of the solenoid coil is fine. This is likely the case. If it does not turn over, you have a problem with the black ground wire.
At this point you've determined you have a good solenoid and starter and that the solenoid is grounded properly. The problem is, as explained by others, the daisy chain of the safety switch, pto switch and ign switch. Those are all in series. When working properly, +12 volts starts at one end, and passes through each of those, and ends up at the purple solenoid wire(when you are trying to start it). My recommendation from experience is, as bert indicated, just go ahead and replace the safety switch.
If you are so inclined and want to spend the time, you can use a voltmeter set on DC volts and a range to measure 12 volts. Connect the black meter lead to the negative batt terminal and with the purple wire disconnected from the solenoid, touch the red meter lead to the purple wire. Do whatever you need to do to start it(pto off, ign on, brake engaged etc) and see if you measure 12V. If you've done everything up till now, then you will NOT see 12 volts, meaning one of the switches is NOT working. Trace the purple wire back to each device and see where the 12v appears.
Having said all that, my guess is the pto switch is OK, and the ign switch is OK and the likely culprit is the safety switch. That's why we are saying to just go ahead and replace it. It's not a costly part.
Good luck!
alitterit
Dirt, Yes the mower will start because by jumping the starter you are bypassing that whole safety circuit and is not recommended for obvious reasons. Bert hit the nail on the head with his post though, easy and cheap to replace the switch and get you back starting/ running again as it should be.
Dirtbmw20
Thanks everyone very much for the replies back. Sorry for the delay in returning back to the forum, but with no computer at home (only phones) and 2 kids running around, I JUST got time to mess with this on Monday. Had to put a new battery in it anyways, so I went ahead and replaced the safety switch at the brake pedal while replacing the battery.
Still not EXACTLY sure of the problem, but I'm pretty sure I figured it out, won't know until I can re-wire the switch. When I unplugged the connector from the brake switch, one of the metal terminals fell out of the connector cavity, so I "think" that is my problem, and why it has been intermittent. It's only connecting on 3 of the 4 terminals on the switch.
NOW..... here's the damn bummer. JD only sells the connector CAVITY, not the connector with leads. So I either have to build another terminal block with a bare cavity I got from JD, or just straight wire each individual wire. Has anybody ever come across this before ?? I am a parts guy by trade, have been in the auto parts business for 40 years of my life, and so far General Motors is the only company I have come across that doesn't sell connectors with leads, until now. JD dealer says only way to get the wiring is to buy the whole harness. Same jackass engineer must design for GM and JD too....... :mad:
Boobala
Check out this video ... might prove helpful ...
https://www.youtube.com/watch?v=Yiimgl-Rdmw
I use these connectors all the time ... best part is you can take the splice apart at any time with cutting the wire great for a situation like yours ( I M O )
you can get them here ... https://www.posi-products.com/
I have bought some at ADVANCE Auto Parts also..
