Jetblast
I am not saying the ZT2800's on my Exmark whine, they scream AND the darn thing doesn't even budge. Today I discovered that when it does this if I pull back into reverse, then push forward the mower will move with no unusual noise.
Is the ZT3100 significantly different?
Is this happening at standard mowing engine RPM (full throttle?) Is your hydro reservoir filled with oil to the line near the bottom of the tank? If "yes" to both, screaming hydros would be a sign that the train has seriously gone off the rails somewhere. Nothing normal about that. What did your dealer say about it?
The ZT-3100 has stronger and longer lasting steel cut gears; charge pumps for quicker response, more weight capacity, faster speed; and relief valves to protect the system if overloaded or overheated. Years ago the ZT-3100 was sold by Hydrogear to manufacturers as a heavy-duty version of the ZT-2800, but eventually it got its own name.
