StevenS001
Hi all,
I am having a problem with my Husqvarna YT48XLS. Recently, I had to replace the bushings on the front wheels. The right front wheel refuses to stay on. I have replaced the bushings twice, replaces the washers, E-rings as well as had to replace the wheel itself as the bushings were loose and could rotate in the wheel. I just placed a new wheel and bushings on and again the wheel came off within minutes. I don't know if this is a problem with the spindle or simply that the e-ring groove is worn. I wouldn't suspect given that the mower only has 180 hours on it however my land is extremely uneven.
Any thoughts would be greatly appreciated.
Steve
Steve
