turbofiat124
- Mar 23, 2011
- 288
Ever since I ran over that shepherd's hook my daughter threw out in the yard last summer, my lawnmower has not been right ever since.
This was what it was doing:
Then all of a sudden I hit a large stick and it starts making this ungodly noise where one of the blades was hitting the deck. So I pulled the blades off and sure enough they were bent up pretty bad.
So I installed new blades and it fixed the problem for a few mowing cycles. Now it's doing it again!
I put the mower up for the fall and decided to just mess with it in the spring. Since we had a drought last summer and there was really no grass to mow. So I got it out today for the first time this season to knock down some stray weeds and mulch some leaves I missed last fall before the grass starting growing. I don't fertilize my yard and I have a zoysa grass so it doesn't start to grow until mid May.
Here's what I have checked so far:
Tire pressures
Cracked or bent spindles
Obviously bent blades (underneath deck)
Adjusted nut on left side of mower to level deck using bubble level.
Deck wheels.
Checked to see if the bar that goes from the deck to the front end is still there (I lost the original one)
So far here is all I can find wrong with the mower.
With the deck set at "3" where I normally mow, the wheels on the "fixed side" of the deck touch the ground. The ones on the "adjustable side" lack about 1/2" from touching the ground.
I tried adjusting the deck to where all four wheels contacted the ground (in my level concrete garage). Well this threw the deck off (using my bubble level) and seemed to make it worse. I recall that the owner's manual said to set the deck height to where you want it then adjust the deck wheels to where they would make contact with the ground. The thing is there is no adjustment on these wheels, just holes. Seems like when I got this mower back in 2009, they did but now they don't and I have no idea why (deck wheels worn out?).
So I proceeded to raise the deck height up to where the deck was level using a bubble level. So now the deck seems to be level (side to side) but the wheels on the adjustable side no longer contact the ground.
I'm about to pull my hair out on this one. Do I need to pull the blades off and check to make sure they are not bent again? I don't recall hitting anything hard. I rotated the blades and eyeballed how far the ends were from the bottom of the deck. They seem straight just from doing a visual inspection.
What else could it be? Do all four wheels need to touch the ground? I can't think of anyway to adjust them unless I drill a new hole in the deck.
Would replacing the deck wheels do the trick? They do seem to be worn out a bit.
Tire pressures
Deck wheels.
