RangerJ
I have a 2009 Troy Bilt Pony that has been issue free until last year,I replaced the solenoid and it started and ran good for a while,then it would only spin the engine once when I turned the key and stop and then repeat,so I replaced the starter and it it started again,but each time it hesitated like the battery was weak,but the battery test good and stays on a Battery tender year round.Then it quit cranking again,same syptoms,so I repaced the solenoid again and it worked again.NOW today it all started again with the same issue of spin and stop.Can anyone tell me what to check or do now? Thanks
