michigan_Rapter sd
25 years ago my wife brought home a new roller for me her dad had found a guy making - 24" 48" pipeline of some sort with green epoxy under the red he used to disguise it - and 1/4" ends welded on - without the water my friend and I couldn't lift it out of the truck so we drug it off with the truck in a ditch. I have always wondered what the weight is filled but I do know it will push rocks into asphalt and crush rocks when you go over the driveway. guy built it like I would have with nice pillow blocks for the axle bearings - only thing is he made it with a pin hitch and some day I am going to covert it to a ball hitch for more movement and on my last lawn tractor it was wearing thru the factory hitch. lately I have been using a honda 4 wheeler to pull it. seems like a person with time and a good welder would produce them and sell them around here - have never seen them since then :/
Neighbors with a 16hp have to drain it half way to pull it up mild hills. and I learned to never try to use it on ground you just graded and thought you had compacted some - when we did the new driveway a couple years ago I tried compacting the dirt we finished the edges with and had to get the truck and tow strap out
