I also have a John Deere LX277.  it is 17 years old and ran until today.  No previous issues with ignition switch.  Okay, with that said, here I go.  There are three stages to the ignition switch on the LX277.  Off, On, Start..After cranking, release key, and it automatically returns to on position.  NOW, when turning the ignition key from OFF to ON, engine starts turning over.  Again, engine starts when turning key from OFF to ON position, and not from ON to START.  This should not happen.  Does anyone have experience with this issue and if so, if you were able to correct it, how did you do it?  New Ignition Switch and Board?
Thanks,
JH
