john deere GT 275 won't turn over
wweis4663
Hi
Does anyone have an idea what my problem could be on this model?
Engine will crank put will not turn over as if was out of gas. I was using the tractor to cut grass and I turned it off, try to start it again would not kick over just kept cracking.
Thanks
Hi
Thanks
Again please read some other posts and try to pick up on correct words.
It is very hard for us.
All we have is your words and if your words are confusing it makes our life really hard.
Some like a challenge but most will just bypass your post and answer something a bit easier.
We also need the engine make & model numbers ( not Hp that means nothing )
Assuming you have not blown up the engine it either is not getting spark or fuel or both.
So start by pulling the plug & checking for spark.
