Hey guys! I have a John Deere with a Kohler CV15-41562 Engine. When I got it, the fuel system was ancient sludge. I dropped and cleaned the tank, replaced the hoses, and cleaned the fuel pump. I cleaned the carb as best I could. It will start choked, and I even mowed with it for a few minutes. Now it will only run a few seconds and die. So I'm guessing it's the carb. When I bump the key with the fuel line off the carb, the pump shoots quite a bit of gas out so I'm pretty sure the pump is good though this is the first one I've messed with. Just seems like a large diaphragm. So with that being said, is there any way to remove the jets on this carb? It doesn't look quite like the carbs I'm used to. Or do you guys think something else is to blame?
Side question: Engine revs up when brake is depressed. Are the brakes on these hydrostatics more like a clutch than a brake?
