Need some help. I'm working on a Stihl MS250 chainsaw that won't idle. I have done the following and not sure what else to check.
Has compression
Replaced carb, and plug
Checked fuel line, impulse line, and intake boot for leaks
Adjusted idle, high and low fuel screws
Both carbs have same symptoms.
Has compression
