B&S OHV Intermittently Dies or Hard to Start
emitflesti
B&S 121602-0269-E1 001214 FA
This is a new problem. Last season, engine started with first pull, no primer, and ran tops.
Now, to start, I have to press the primer bulb 4 times. It may not start on the first pull, but it usually will on the second, though it huffs and puffs and misses incredibly. After 10 seconds, it runs fine.
At some point after running for 10-20 minutes, it will miss and die. I have to re-prime to get it to start, at which point it goes through the same start scenario as described above.
I have completed the following:
  • Cleaned fuel can
  • Replaced fuel
  • Cleaned fuel tank
  • Inserted fuel filter
  • Removed and cleaned the carb
  • Replaced magneto
  • Replaced spark plug
I have a carburetor, air filter and pre-cleaner on order.
What am I missing?
TIA.
ef
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
  • Cleaned fuel can
  • Replaced fuel
  • Cleaned fuel tank
  • Replaced magneto
What am I missing?
TIA.
ef
Have you tried a new fuel cap?
