reynoldston
- May 23, 2011
- 5,705
Then I do tire work in my shop I always clean the wheel bead with a wire brush after the tire is off. Then when I install the tire I use a product called bead sealer. This comes in a can with a brush built into the cans top. If you don't do much tire work a can of this will last for a long time. I also find that a little of this sealer around the valve stem also helps. I always install new stems with any tire work.
