leadtheway
So i have a IS2100 61" with about 800 on the clock. Been running fine till about a couple weeks ago where it would intermittently just Click when turning the key to start, but battery was good so i figured I'd start with the solenoid. Replaced that and same thing, so think maybe start stuck so i tap a few times on starter and try again, now it turns over but doesn't fire. Not sure what could be going on here, I changed the solenoid hot and accidentally arc'd with the wrench when it hit the body of mower, was thinking maybe i blew a fuse or something, Are there any fuses that could be indicative of my issue, if so can anyone tell me where all the fuses are on this?
Thanks in advance
Thanks in advance
