can't push mower
mwarr
How do you roll a Honda H3011H hydrostatic riding lawn mower? Surely there is an easy way. I had to slip a hand truck under the rear end to get it out of my front yard.
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31763800.pdf Page 18. Page 18 has picture and complete instructions. By the way that is the owners manual. I suggest you download it for further reference.
Operating the transmission release lever while the engine is running could cause transmission damage.
To operate the transmission release lever:
1. Stop the engine and apply the parking brake.
2. Place the shift lever in the NEUTRAL position.
3. Move the transmission release lever down to the lower groove (red dot)and lock it in place.
4. Release the parking brake carefully.
The mower will not start. It will not roll because of the hydrostatic trany will not let it.
I need information on how to put the mower in "free wheel" so I can push it.
Normally, I put in neutral with mower off and the motor starts right up. It appears to be a switch or starter issue.
Luckily, I had just finished mowing and picking up leaves. This gives me 1 week to fix.
thanks
thanks
Page 18 of the manual that I posted a link to has a picture of where it is and I posted instructions on how to do it.
