Hello,
My name is Petros. I was looking for some info regarding weed eaters with saw blades & noticed this forum. I am in 2 other forums but they are truck/SUV related.
I have a 2 3/4 acre lot in Orangetree, FL 34120 (Northeast Naples). I've owned it for 10 months. About 2/3's of it is cleared. The rest has pine trees, I believe 1 oak tree, & some trees that my neighbor said are called Brazilian Pepper trees. I will leave the Pine trees alone except for any small pine trees that may come up and that the brush mower can tackle. I will be renting a walk-behind brush cutter to help clear the 3 or 4 Brazilian Pepper trees that I have & to mow the tall grass and any small saplings that come up.
The lot is fenced but the fence was knocked down towards the rear & I repaired it. There was a lot of brush/weeds covering the fence which I have partially removed but I still get plenty of weeds growing along the fence & a machete is not enough to remove them. Eventually I will look into buying a brush mower but renting for now. What I DO want to buy for now is a weed eater with a saw blade. I've seen a few Youtube videos of people cutting saplings that are actually a bit larger than what I have with that set up.
I am looking for any recommendations (btw, gas powered) regarding what brand & saw blade to go with.
So far I've read that a straight shaft weed eater is better for this & that a 4 stroke engine is better than a 2 stroke. The straight shaft makes sense. Don't know the benefit of 4 over 2 stroke engines except for not having to mix oil/gas.
I don't care about ease of switching back and forth from saw blade to string. I wont have a need for the string.
Thank you VERY MUCH for your assistance!
Petros
BTW, not all parts of the fence are covered in weeds & brush. Just some areas.
pics of the fence:
Petros
pics of the fence:
