smullen
Hello,
I have a Hustler Raptor 52" Model # 933077 with 23 HP Kawi engine.
I bought it from Lowe's maybe two years ago as I live in a rural area and we don't have a lot of options... Its either full on commercial place, Lowe's or Walmart...
Anyway, the mower has been pretty good, seems too use a lot of gas and spin out alot on any kind of incline, but other than that I enjoy using it.
My issue is, Saturday, when I was cutting the lawn, and the fron of the deck just dropped to the ground. Upon further inspection, the one single bolt that holds it deck up too the frame, seems to have just snapped off...
Its a strange bolt, kinda reminds me of a tuning fork... By that, I mean, it is a Threaded rod maybe 7-8" long, that has two flanges welded on the bottom, the top, used to go though a round bar part maybe an inch in diameter at most and that part went though a mount spot on the center of the deck. Anyway, the threaded rod, snapped and it now to short to go through that round bar part or I count maybe put another nut ant lock washer on it to put it back together...
Also, it looks like the round bar stock part that the bolt goes though was threaded at some point and the threads maybe worn or stripped out. The bolt's threads will not even attempt to bit onto the bars threads. I'm not sure they even did though.
I went and downloaded the parts manual PDF and I in the deck section, I can see where it connects/mounts to the frame and the deck, but it does not show or list my broken parts...
I've attached pic (or think I have, not familiar with this forum software), so someone might better see what I'm talking about...
Any ideas, how I might get new parts and what I'm looking at cost wise???
Lowe's is pretty useless in this, they don't service anything or sell much in parts for it....
