Ken, Thanks,  If that is the culprit a lot of work for a simple fix-ha ha.  From new I did have problems with dirty intake throat and could not figure it out. At about year two I finally found that the 90 degree rubber connection had not been seated by the factory at the bottom of its annular groove in the intake hole (could not see it from above)..  That had let the Intek suck dirt while I carefully cleaned and changed the air cleaner above.  I just read on another site that Briggs actually replaced engines due to this problem. How mine survived is a mystery.
As noted the engine runs ok now but surges like governor is working even in constant state. I will look at the springs.
Something I found I did not mention previously. While cleaning the head I noticed one edge of the casting had a shiny mark. I intended to "clearance" it before assembly, but forgot. After I found the spark module rotated .010" beyond spec at the right side I guess it was a contact point with the head? Vibration?
