SeniorCitizen
- Aug 28, 2010
- Threads
- 146
- 2,333
i would take the bowl off. you can see it move when switching the on, and off.
I take it you've had a few of these apart. Did you find anything in particular that would inhibit fuel flow either to the carburetor or from the bowl to the combustion chambers?The fuel inlet on that carb is in the side of the jet tube so it works the same.
Chances are the main jet will be tucked up inside the tube and plugged off so it can not be "fiddled " with.
Shinny bums at the EPA making useless laws to make it look like something is happening while actually making no difference at all.
Down here they use RACIST & ZENOPHOBIC reasoning that tighter emissions regulations will stem the flow of cheap dirty forein imported engines into OZ.
A bit silly being that Briggs closed our last small engine plant this year and of course the Chinese can make clean engines just as easy as they can make dirty ones, it just costs $ 20 more.
