shiftsuper175607
- Sep 11, 2013
- 1,000
B & S Vanguard 15.5 HP model 280777 type 0691-E1 on a Dixon ZTR 4515B
Hello everyone,
I hit and 16 inch log about 3 inches diameter, motor died immediately.
I pulled it back to the shop.
When I tried to start it was trying to backfire.
I removed all covers and flywheel bolt.
The flywheel and crankshaft seem to be in correct alignment with the key intact.
I thought I would ask you guys if you had any ideas beyond a partially shared key.
But again, everything look straight.
I have not been able to get the flywheel off yet, still working on that, so I came in to ask you guys for some help.
Thanks a lot.shift
PS. what is the torque for the flywheel bolt?
Hello everyone,
Thanks a lot.shift
