fredthetiredman
- Sep 19, 2016
- 4
Hello,
I have a lgt2654 96045003700 Husq 54 inch mower....
I have the fender hydo control and NOT the pedal control.
After 106 hours of usage the drive belt came off,which i find out that is the expectacy of the drive belt. The drive belt also (somehow) knocked out the the hydo "pull out to disenge" the tranmission rod/control.
Spring Rod Bypass
Part Number: 532415743
Part 99 I believe.....Naturally the replacement one looks much different then the missing original. The parts diagram really doesnt show how it needs to be reinstalled? I think when I temporarly got the drive belt back on- I noticed a black lever that it may attach to....but i am unsure where and how it connects? Does it have a return spring? Does anyone have a Good pictures that show "how it was before?"
Does the fender control use a different rod?
Thanks for your time
Spring Rod Bypass
