Fuel flow issue
SFE
My Craftsman 4.5 HP push mower isn't getting fuel. I can prime the carb and it will run until the prime is consumed then quits.
A brief history:
I mowed one week and put the mower away. Got it out the following week and it wouldn't fire at all. As the mower is about 10yrs old and I've never had to replace the spark plug I thought that was my problem. Replaced the plug but it didn't help. At that point I pulled the fuel bowl off the carb to check and clean the main jets but still no luck. I then removed the carb and cleaned with carb cleaner (spray) as best I could and blew out with compressed air. Replaced the carb but still wouldn't start. It was at this point I began to "prime" the carb to get it started but it wouldn't run beyond the prime. While I had the carb off I noticed several "welch" plugs in the carb and I figured there was some dirt under one of them keeping it from running as it should. I ordered a rebuild kit, removing and cleaning under the welch plugs both with spray carb cleaner, thin wire and compressed air thinking surely it would run now. NOPE!
I'm at a loss except for one discovery. This carb, a Tecumseh has a primer bulb that I noticed has cracked at the very base. Could it be that this is allowing a vacuum leak not allowing the carb to draw the fuel as it should? If this is my problem can it be replaced?
Answered in other post. Please do not double or triple post. We all look at every post.
Sorry! New to the forum and had spent some time explaining my problem and thought I had posted but site was HI-JACKED by some sort of AD virus pop-up?? and had to shut down. When I came back to the site I couldn't find my post ! I thought it was lost. I had to go to work. Upon returning to the site I found the Tecumseh forum section and reposted. My mistake, my apologies.
If you click on your own forum name either in he side bar at left screen or the task bar at the top you will be taken to your page and all your posts.
And yes there is a Vietnameese hacker who has worked out how to get into the system.
Product of third world poverty you will just have to get used to it .
