PyhooyaBooya
The only brand of trimmer I hear to buy is Stihl. They are expensive. Are there any good brands that have commercial trimmers that aren't in the $300 range?
That's a tough one. Cheap trimmers don't last as long as expensive ones and they're also a bigger pain to use, especially on heavier jobs like clearing thick ditch grass. Aside from the power differences, a lot of it has to do with the cheaper ones using .080 line and having uncomfortably short shafts, while the better ones use thicker .095 line and can move with you gracefully and reach further without turning you into a hunchback.
Both Ric and JDgreen are right, but maybe there's a compromise for now. I understand that you're getting a landscaping business off the ground with a small budget, so for now I might go for a Stihl FS 45. --> FS 45 Trimmer From STIHL <-- It's an .080 trimmer at around $150 with a longer shaft than many, so it's very well regarded. It's also the number one pick by Consumer Reports.
Once you've had some solid accounts for awhile and your .080 trimmer is piping up and shooting it's mouth off too often, look into a commercial .095 trimmer from Stihl or Echo. I use an Echo .095 trimmer on my hundred yards of crazy ditch grass with a strap and J-bar, and it's been great, but I'm sure I'd use a Stihl just as happily. No smoke and mirrors, these are great brands who deserve their reputations.
At some point you may be confronted with the idea of a 4-stroke string trimmer, and my advice would be to try before you buy. The extra tallness of the engine due to the valves on top of the head gets in the way of my right elbow and makes them virtually unusable. I'm 6'1". If you're less tall it may not be such a problem.
JD I know you're not real big on buying equipment but I think you have to remember that he is talking about running or using this equipment in business, not around the house. 50 hours of use EACH per year for your Trimmers is fine for around the house but not when you're in business, when you could be using a trimmer or an edged and put that much running time in on one in a week.
BTW, Jetblast, WTF is ditch grass? I have never seen anything .080 line could not handle.
