Harold2689
- Sep 17, 2016
- 12
Hello!
I have a Murry lawn tractor, Model 40604B, manufactured: 0272. It has a 12HP Briggs & Stratton engine. It was running perfectly, when suddenly it started running very rough, and at the same time, started blowing blue smoke out of the muffler. I removed the "hood" and shroud of the mower to gain access to the engine, and found the spark plug and the muffler both LOOSE. I also removed the upper air cooling housing from the engine, and found the cooling fins around the cylinder, and the area around the head, packed with mice nesting material! After cleaning all that out, I noticed that the bottom third of the head seemed to be "wet" with oil. After changing the spark plug, and tightening the muffler, the engine started up, ran for about 30 seconds, billowing blue smoke all the time, and gradually running rougher and rougher until it died again. I removed the cover over the valve springs, and "thin" oil poured out. By thin, I mean gasoline mixed with crankcase oil.
I'm thinking possibly a blown head gasket? What say you guys? I cannot locate a manual for either the engine or the mower.
Thanks in advance for any light you can shine on my problem, and any help or suggestions you may be able to offer.
Harold
Harold
