ukiltmybrutha
- Jul 23, 2016
- Threads
- 2
- 21
Hi,
I have the subject mower and it has had numerous quirks during the nearly 10 years that I have owned it.
I'd like to know if you can help me start to knock these items out. I really have spent a fortune on it over time and it does cut but it has numerous issues.
1st problem:
The tractor randomly does not start. When it fails to start, all you hear is a click. The only way to get it started is to quickly turn the key (usually 20-30 times) and then it starts fine. Rocking the mower back and forth during this time seems to help as well. Vehicle has a new ignition switch and I am running a car battery which didn't fix it.
2nd problem:
Somewhat tied to the 1st one possibly?? If the mower sits for a few days even after running for a few hours (I verified the battery is being charged), the battery dies. The battery dies even if I remove both terminals to it after mowing. I got so sick of problem 1 and 2 I decided to use a large car battery. This helped a bit, but I am glad my battery has a handle because it is always needing to be charged....and yes it is any car battery that I use.
3rd problem:
There is a wire that I disconnected years ago after not being able to get the tractor started. I removed this wire and the tractor would start and vice versa. Does anyone know where it goes?? It is the black pictured wire which ends in a female spade at the extreme right hand side of the pic.
4th problem:
Getting off of the Seat no longer causes the tractor to shut off. I can mow in reverse, that is pretty neat....but I'd like to at least have the option of having it cut off when getting off the seat or throwing it in reverse. Maybe the wire from the 3rd problem has something to do with the second?
5th problem:
The PTO blades do not completely disengage when I turn them off. They slow down to about half speed or maybe a little bit less.
I just swapped all 3 belts and put the spring back in the right place but this did not resolve it.
Thanks for any help with any or all of these problems!!
1st problem:
2nd problem:
3rd problem:
4th problem:
5th problem:
