wfsway
Forum, I am new to this site and wanted to share my experience and efforts to restore the titled subject. I am Quality Engineer by trade and explains why I am so detailed and meticulous about this restoration, and was great experience to learn about this fine equipment piece by piece. Presently I will just list the actions done without explanation.
* Blasted aluminum mower deck to bare metal, repaired 2" hole in deck by aluminum welding and primed with Zinc Chromate.
* Single stage topcoat Toyota dark metallic gray.
* Rebuilt recoil assembly, blasted and painted Candy Apple Red.
* Reworked rusted out areas of grass bag frame assembly and repainted with POR 15. New cloth bag.
* Rebuilt rotor driven disk and brake assembly and surfaced contact faces, new driven disk.
* Top end rebuild engine GXV140 ported and polished intake/exhaust.
* Re-seated valves with lapping compound.
* Drilled oil ports (1mm) larger.
* Added inline fuel filter, new fuel lines.
* Zinc anodized small parts as dissembled.
* Dissembled SX Transmission refilled w/Honda gear fluid and restored.
* Wheels reworked with new bearings. Rubber switched front to rear.
* Restored handle mechanism, cabling and bearing points.
I am sure I have left something out but you folks get the picture, what an experience. I have not put the new stickers caution etc. for the paint to fully cure. Thanks to comment, question.
