Model number
Balancerocker
I have a Husqvarna LC221A mower with a B & S 625EX motor. Where is the model number located. I can see the serial number, but not the model number.
the model number of the mower should be a white sticker probably by the handles. the engine model type and code is on a plate by the muffler on the newer units and stamped into the blower housing on older units.
I was looking for the engine model # and my model (built in 2016) did not have a plate by the muffler. After searching through the engine manual, I found a reference that the model # is on the side of the engine block near the oil filler tube. I had seen that number, but thought it was a part #.
